Transducer for 305 ex
Sloppy Joe's
have to buy a new transducer for my 305 Express and Hull there is the preparation, so I wanted to understand what I have to take:
Arimar B175 Low 0 °
Arimar B175 Low 12 °
Arimar B175 Low 20 °
Thanks for your help
Arimar B175 Low 0 °
The model depends on where you mount it on the hull. The angle of the deadrise at the mounting position determines which model to use.
The spot to put it is critical and you should check both with Grady tech support and other owners of the same hull
Sloppy Joe's
Exactly, in fact, in the hull of the 305 Express it is a predisposition which changes the angle of the hull and I wanted to know if someone had already mounted a transducer low profile.
