- Mar 16, 2021
- Age
- 52
- Overnighter
Hello all,
Getting ready to install the plastic gas tank the p.o. included. I've researched a bit and crossed off several questions on my list. These ar what I have left.
1) being a plastic tank, I presume I dont need neoprene pads. If not, should I block it up with pressure treated 2×4 or foam to make it level with the floor?
2)I plan on using 2x pressure treated across the top of the tank and under the cover as bracing. Should I wedge some along the sides to secure the tank laterally? Better ideas?
3) what would you use to deal the cover to the floor?
Thanks in advance.
Thanks in advance.
