- Jun 23, 2020
- Age
- 61
- Fisherman 204
Hi all, Bought a 1987 Fisherman 204 center console this year & have spent the season getting to know her. She’s in great shape for her age, transom seems quite solid, My concern is regarding the self bailing cockpit design of the boat & what type scuppers are best.
I bought her set up with the ping pong ball type scuppers & struggled all year to keep them clear of debris. As much as I cleared them I’d find in short time leaves, debris, crab legs...... kept clogging them. When clogged they just don’t work as designed at all, allowing water to seep in & preventing it from flowing out. The past owner also used drain plugs to close the deck drains in order to keep out water due to the clogged scuppers. The bilge hatch cover was also kept loose for greater access to the bilge area than the 8”round inspection plate allowed.
the other day I went out with a buddy fishing to drift live eels for strippers in the Long Island sound. As we drifted we began to take rollers at the stern which washed over the low wide transom of my boat. The water washed into the bilge & stayed! I removed the drain plugs at the scuppers but little escaped through the set of four. Water also quickly filled the bilge below & the pump was not only overwhelmed but it too was clogging from debris & leaves within the bilge area. What a mess.
So...... we did make it back that night, lol.
Once tied to the dock I ran the bilge pump 30 minutes to clear the boat of water. I had to plug the deck drains again just to do that as they were well under the water line with all the water weight.
The next day I researched the issue & saw lots of conflicting advice online, including here at Great Grady.
Here’s my conclusion & take on this. Please feel free to chime in & give your advice.
I am discarding the ping pong type scuppers. Bad design IMO. The ball scuppers are three piece, including the clear plastic housing & the plastic ball that floats within. Behind this, against the hull is a gasket with a hole that the ball settles into to stem water flowing into the boat. Simple.
In reality the hole in the gasket is much smaller (7/8”d) than the deck drains themselves (1-1/4”d). The gaskets are also installed with the holes at the top side to cause the floating ball to meet the opening within the top of the housing, hopefully plugging it.
This causes the large drain holes in the transom to not only be reduced in size & flow but creates a dam at the bottom of the drain that quickly clogs. The drains clog with any debris trying to flow out the transom.
I thought why would I have such an issue with a 33 year old boat that has lasted this long & not swamped routinely or outright sunk years ago. Surely the original scupper design was working well at some point. I ordered four Attwood flap scuppers & will be fastening/caulking back in the bilge hatch Itself. I’m also putting in a new 8” access port to clear the pump of any debris that does attempt to clog it. The boats drains are all four at 1-1/4” diameter & that should allow a lot of water to escape that does backwash the stern & deck. With the hatch caulked that water should stay on the deck long enough to escape out the drains.
why would anyone use the over engineered ping pong ball type scuppers that clog & reduce the drain hole size? They don’t work well at all.
what is everyone else’s experience with these?
