1987 Yamaha 175 Oil Issue
ahill
Manatee Pocket, FL
The oil from the remote reservoir is not being pulled to the block mounted reservoir on a friend of mine's boat.
Any helpful hints?
First step is to see if the manual overide works. The switch is located on the powerhead under the cowling and should be labelled.
If the manual works and the main tank fills, we know the pump is good and the filter. If the pumps hums but the main tank doesn't fill, the filter is probably clogged.
If the pump doesn't pump, it is probably bad although it could be wiring also.
Do the first test and get back. We can go from there.
