1988 Gas Tank for a 19 Tournament
Charlie Brown
Tournament 192
I am looking for a gas tank for my boat. I would like to stay away from aluminum. I can not find anything somewhat close. Boat is in salt water. Any direction would be great.
I went on their website earlier and did not see any good option. If I call do they have more options than what they say on the website? I appreciate the help
In the past they did, yes. It's been a while since I talked with them. Give them your specs and wants (slightly smaller dimensions are OK but not bigger, for example) and let them work on finding something that would work. I have no idea how much more it would cost to have it made to your custom specs, but it might be worthwhile to ask.
For what it's worth - I would be looking to go to plastic, as well, over aluminum.
You might check newer model Grady's, as well - for example, my mother has a 2000 model Tourney and it has a plastic tank. I think it's slightly bigger - but not sure exactly nor do I know if the dimensions would still work for you.
How much larger in each dimension (L, W, H) could you go and still have it fit? It would be good to measure that.
Thank you. I will contact both grady white and Mueller
