- Sep 8, 2021
- Age
- 69
- Chase
new to 1994 263 chase that was introduced with the transom extension. Single 250 Yamaha gets spray wicking all the way up to the engine cover. Cavitation plate sits even with the hull transom….not the added swim platform that Grady used to extend length for this model. water is hitting lower unit above the cavitation plate even with or slightly above the secondary spray flange on the lower unit. 30 inch lower unit standard on, but has anyone tried a short lower unit to alleviate this problem? I would think that there would be a lot of hydrodynamic eddying that would make a short shaft unfeasable. . The water wicks all the way above the engine cover and I’m worried that it will get into the lower unit.
