1994 Chase new scuppers and deck drains
Hockeysurf7
Going to replace the deck drains and scuppers on 1994 GW chase. As for deck drains it looks like I will have to order them from a Grady dealer, found them on this site but can't order them: https://thmarinesupplies.com/products/cockpit-drains?variant=15005756227627 model#TH-1992R i believe that those are the ones i need.
As for scuppers I believe i need 1.5 in. any suggestions on what ones to get?
I have the rubber flap style, tried 2 different brands haven’t had very good luck with them, They still curl up and Get water coming in on the deck in rough seas. I ended up buying rubber expansion plugs with wing nuts and use them when in rough water. And remove them when the boat is in slip.
Don’t forget to pull them when you get back to the dock.!!
