- Jul 23, 2019
- Age
- 78
- Explorer
Ummmm... yeah, I think we already talked about that?6/27/24 Mechanic says, based on what I conveyed that Water Pump needs replacing.
Always good to narrow problems down before throwing parts at it.Ummmm... yeah, I think we already talked about that?![]()
You have a sandy bottom there. I would have the mechanic back flush the saltwater side of the heat exchanger. Some heat exchanges can be opened up and "rod-ed" out. They should be cleaned periodically anyway - they load up on deposits and need to be acid cleaned. Change the raw water pump impeller (probably due anyway). Flush saltwater hoses.
Other than checking coolant level I wouldn't touch the fresh water side of the system. I would be a little concerned about your overheating and blowing coolant out. Get the heat exchanger working and test. Don't let it overheat again though!
Hopefully you have a engine coolant temperature gauge that you can monitor. You should be able to see the engine warm up to around 185 degrees at which point the thermostat opens and allows the heat exchanger to cool and hold temperature. Check the thermostat opening temperature with the mechanic.
6/29/24 thanks so much for your comments:You have a sandy bottom there. I would have the mechanic back flush the saltwater side of the heat exchanger. Some heat exchanges can be opened up and "rod-ed" out. They should be cleaned periodically anyway - they load up on deposits and need to be acid cleaned. Change the raw water pump impeller (probably due anyway). Flush saltwater hoses.
Hopefully you have an engine coolant temperature gauge that you can monitor. You should be able to see the engine warm up to around 185 degrees at which point the thermostat opens and allows the heat exchanger to cool and hold temperature. Check the thermostat opening temperature with the mechanic.
There is an automotive style centrifugal pump on the engine. No impeller to replace. These pumps usually leak at the bearing and should be fine. Assuming you got the thermostat in correctly and gasket is good you should have to do anything here either. Just make sure it has water and antifreeze and is "burped" to get the air out. Run it with the cap off and add water if needed. The antifreeze has corrosion inhibitors in it so even though it won't freeze by you it still needs to be in there.6/29/24 thanks so much for your comments:
1. As to "not touching the fresh water side of the system", please elaborate? My thoughts (probably wrong) are there is two water cooling accesses: sea water pick up through the stern drive and the quick connect hose used on the lift? The additional circulating system being the "self contained" antifreeze? What circulates the antifreeze thru the heat exchanger?
Yes. Have your mechanic check it.You indicate "Run it with the cap off and add water if needed.". Do u mean antifreeze water mix on top of heat exchanger?
