1995 Gulfstream Interior Cousions Rebuilt
jweschler
I am in the process of re-doing the entire inside cabin cousions and making the three that go over the toilet and span the walk way down below. I have bought all the fabric 11.5 yrds, I hope that enought. Some new foam for the new cousions and monel staples, t-nuts to replace the rusted ones that GW installed on the marine grade plywood. Don't know why it was not SS? New 2 in. webbing for the top bunk, new thread. Need to purchase 4' x 8' marine grade plywood for the two new cousions. I recieved some emails and pictures and measurements from a guy that has a 2000 Gulfstream. I hope they are the same size, if not has any one performed this same build or can get me detailed size and mesurments? Thanks, Joe W
Kenlahr
Maryland
Hi Joe. Keep us posted on your progress. I want to see that new cabin!!
jweschler
Updated on My Cushion Re-Build
What the boat use to look like.
Here is the new filler.
Here is the new top berth.
Kenlahr
Maryland
Joe; looks great, the pictures are a bit big. How is the cabin fit?
jweschler
Here is what the bottoms look like.
Here is the first wedge cushion.
Here is the second.
And the third.
This is the completed set not yet in the boat those will come later.
jweschler
I wanted to let everyone know how much this project cost me in total.
Scrap pressure treated plywood from local lumber yard. $11.75
Joann's
Fabric 11 yards and white 2" strapping for top bunk. $150.00
Sailrite
Foam Reflex Biocide 4" x 48" x 81" $136.00 more then half left over
White Thread 350 yards $4.50 YKK #5 Zippers 13' 7.50 (2) Zipper pulls $4.50 Underliner for plywood in Gray $7.50
Monel Staples and Hand Stapler and SS t-bolts $50.00 from boat US
Total Cost= $371.75
My Time: thee weeks of total work, so a total # of hours 32 good winter project
jweschler
Some tricks I learned on the way.
I had to cut down the foam a 1/2 in. because I did not take in to account the thickness of the plywood. So the cushions looked to poofy, so after I cut them down they are looking great. I think I was pretty smart, I needed to cut the 1/2 in. and I cut the pattern with a electric kitchen knife. So I used that and I took two pieces of 1/2 in. copper pipe and cut a slit in the foam about 7 in. from the side with a serated knife about a 1/2 in deep. Then I stuck the pipe in there and put the other on the out side and ran the knife on top of both pipes. I did that all away around the pattern, and then in the middle I used the knife and keeped it parrallel to the foam I already cut and it turned out great.
jweschler
Hello All, Here is the final picture of my winter 2007/2008 project. I was a very fun learning from a book and a DVD that I bought for $20.00. I am also working on updating / converting my reat seat from the old 12 screws attachment to a new 5 SS u-clip that I can slip on and off for the winter months. I am also sewing new vinyl roll and pleate and flat in sea white that matched perfect. It was more expensive then chalk, but I did not want to replace the other cushion that did not need it right now. If anyone needs any advice please do not hesitate to PM me or respond to this post. Thanks for giving me this time to show you my new cushions.
Thanks, Joe W.
