2 inch gas fill cap??
lime4x4
Palmerton, Pa
I have a 86 grady offshore i managed to loose the gas fill cap for it. The opening measures almost 2 inches any ideas where to get a replacement? I've looked into relacing the whole fuel fill but the exsisting opening is bigger then the replacement fills will hide.
Most of the caps were Perko and if so, replacements are available.Note that usually the size mentioned for a fuel filler assembly is the hose size and not the cap overall size.
A call to Grady support may help. They may know if Perko was the supplier for that model.
You need to get the right type too, vented or not. If you have a separated vent, then you need a non vented cap.
here is a link to some Perko products that might be what you are looking for
http://www.perko.com/catalog/non_epa_ve ... omponents/
