- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
I've done some searching and checking in a service manual (although I'm not 100% positive that the manual is for my year engine). I'm "OK" when it comes to electrical stuff with Mercruiser's, but less so with this outboard as I have little experience (none) with big OB's.
So... I noticed the Yamaha dash voltage gauge blinking at 11.8 (same for both batteries). I tested the voltage with a good voltmeter right at each battery. With the engine off, I get about 12.3v (no idea of age of batteries). With the engine running I get 12.0v. The engine starts right up and runs, although at this point I've only ran it (1) for about 30 minutes during the test ride before purchasing and (2) about a total of 30 minutes on a hose (it doesn't seem to like to run as smooth on a hose).
First, I started poking around (trying to find the voltage rectifier, which I have not, yet). I was going to try and check voltage there - but I was/am still a little unsure of how to do that as the manual says to remove fuses? Anyways, I found this wire broken off. It's the green one with the small clamp on it at 10:00. It should be connected to the silver post with the green dot on it. I'll reconnect this tomorrow and check things out, but what is that?
Second, the other clamp at approximately 3:00... it looks like those leads might be the charging leads that go to the batteries?
Third, should the charging voltage be roughly what it would be coming from an alternator in a boat or a car? Meaning, roughly 14v?
