2000 Yamaha 225 OX66 not holding prime,
smzdano
2000 Yamaha 225 ox66 not holding prime.
Replaced filter housing and priming bulb but still not holding.
If the needle valve in the VST is not sealing, you will loose prime but before I assume that is the issue, do you loose prime when motor not running or when it is running. The later is a whole different story.
If the primer bulb does not collapse but goes soft when running, you have an air leak most likely. If the primer bulb collapses, you have a blockage in the fuels line, pickup or vent.
You also mentioned you changed filter housing. What exactly did you replace? There are multiple filters on your setup.
