2004 tournament 225
Green Pond
Tournament 225
Boat is shrink wrapped. Anyone know if 9” garmin will fit in electronics box above steering wheel?
Don't have that boat, but...
-- In case someone can help, be more specific with the model and the necessary dimensions.
-- Tape a zipper door on your shrink wrap and go inside and measure.
I believe it will I have a 12" lowerance hds. Tight but fits, tilted. And also can close 2 piece glass
I have a Lowrance hook2 9" disoplay in my 225 tornament, fits fine on the stock bracket.
Was able to climb up under shrink wrap at engine. Installed a 9” garmin. Fit fine. Now looking into replacing the illuminated rocker panel switch covers.
Check out new wire marine. Replaced all my rocker panels covers with covers from them.
New wire marine has all the covers. Any chance you replaced the rocker switches or covers for the trim tabs?
Thanks for the help.
