- Jan 13, 2025
- Age
- 60
- Bimini
I was hoping someone else experienced the same issue and figured out the solution. Your guess seems to be the most logical so far, thanks.I was kinda curious about that. It COULD be that the other one is off by enough that it's trying to push/list the boat over (lean over) and it's causing the flatter one to dig in to the water more than usual.
For starters, disconnect the strut from the tab mount and move the tabs manually, seeing if you get full movement. Inspect the hinges/etc really well.
