2006 marlin 5th battery for electroincs
offshore
Having some trouble with all my electroincs and house on one battery bank. Electronics go out when starting engines after a drift. Does anyone know what i should do, maybe install a 5th battery. If so where would i put it.Thanks
Pez Vela
San Diego
There are a number of ways to isolate your electronics, and this is one of them. http://bluesea.com/viewresource/63
Because I have simple needs, I opted for an elegantly simple solution. I just added a dedicated "electronics" battery that is only connected to a fused switch panel and my onboard charger. This battery does not get charged when the motors are running, but only when I fire up the generator or plug in to shore power. This will not be appealing to many, but its simplicity is foolproof, and the battery drain is so minimal (on my boat at least) that charging continuously is just not necessary.
Grog
5th battery? I can see maybe 4 with 2 in parallel (or a 4D) for the house. Get a panel to isolate the motors from the house which will allow the house to be charged once either start battery is charged. Something like http://www.bepmarine.com/home-mainmenu- ... tery-banks should work for you. When you have a start battery tied to house functions you're asking for trouble.
ocnslr
Fort Myers Beach, FL
Stay with four batteries. No need for a fifth battery - just changes in how they are wired.
Two starting batteries, each wired to a regular 1-Both-2-Off battery switch. One battery to "1" on both switches, and the other battery to "2" on both switches. Each engine is connected as the "Load" on one battery switch. Usual arrangement is one switch in position "1" and the other in position "2", but you can use both to start one engine if needed. Each engine charges its respective battery through the main power lead.
Two other batteries should be a matched set of either Deep Cycle or Dual Purpose, wired in parallel. These go to a simple On-Off battery switch, then feed ALL the house loads through the 40-amp (or larger) circuit breaker that should already be installed. Get the wiring for the Auxiliary Charging Lead and connect BOTH engines to this battery bank - that way either or both engines can charge the house bank. No need for fancy regulators, balancers, isolators, etc.
The Charles Charger installed at the factory on our boat has three bank capability, so it charges both starting batteries and the house bank when on shore power.
I set my system up this way in October 2005 when we repowered from a single 250HP OX66 to the twin F150s. The starting batteries were new at that time, and the two house batteries (West Marine DP 650s) were six months old. I just replaced all four batteries in April - yes, they were that 'old' but still doing pretty well. The starting batteries were fine but the house bank needed replacing, so I did all of them.
My electronics NEVER blink when I start engines, and rarely when we hit the electric flush on the head.
I also have two fixed VHF radios, to separate antenna, with one powered from the house bank and the other from the engine batteries.
Brian
