2023 Grady White Fisherman 257, 25'
Mjscms50
Fisherman 209
2023 Grady White 257 Fisherman Center Console, 25’
PRICE: $179,900
Call or text (717) 903-8335
  • Show Room Condition – Stored Indoors Year Round. Located in Ocean City, MD.
  • Yamaha Warranty until 04/10/2026
  • Hull Color: White with black boot stripes
  • Annual Maintenance/Winterization Complete
  • Ready to go with 135 Gallons of Ethanol-Free Gas
  • No trailer
POWER:
  • TWIN, Yamaha, F200’s XCA’s, 4-Stroke Engines: (244 hours)
  • Helm Master EX Joystick & Auto-Pilot
  • Digital Electric Steering (DES) with Tilt Helm
  • Digital Electronic Controls/throttles (DEC)
ELECTRONICS:
  • TWO(2), 12” Garmin GPSMAP 8612 XSV Touchscreens: including Chart Plotter, Sonar, Fish Finder
  • Garmin GMR Fantom 18X Dome Radar
  • Garmin GT36UHD “Transom” Mounted Transducer for Clear-Vu/Side-Vu Structural Scanning
  • Airmar B75 Thru-Hull Transducer
  • Garmin 215 VHF Radio with DSC & AIS
  • (2) Shakespeare 8’ Antennas with Fold Down/Ratchet Mount Stainless Steel mounts
  • Fusion Apollo MS-RA770 Stereo System with waterproof touch screen display, AM/FM tuner and Wi-Fi Bluetooth, Speakers: Bow (2) & Cockpit (2) with Blue LED lights.
TROLLING MOTOR:
MINN KOTA Terrova, 112 LB Thrust, 36 Volt, 87” Shaft with GPS Spot Lock powered by a 36V, 75 AH, Lithium Pro’s Battery.
SPECIFICATIONS:
  • Center Line Length w/o Engines: 24’ 9”
  • Beam Amidships: 8’ 6”
  • Cock Pit Height: 27” (makes you feel very safe 60 miles offshore)
  • Transom Deadrise: 20 degrees SeaV2 progression
  • Hull Draft: 20”
  • Fuel Capacity:135 gallons
  • Passenger Capacity:10
  • Dry Weight Without Engines: 4,300 Pounds
SAFETY:
  • UNSINKABLE, Basic Flotation
  • Bow Grab Rail - Low Profile 316 Grade Stainless Steel
  • TWO(2) Automatic Bilge Pumps (2,600 GPH Total)
  • Cockpit Toe Rails
  • Stainless Steel Bow and console grab rails
  • Self-Bailing Cockpit w/ Cockpit Drains (4)
CONSTRUCTION:
  • SeaV2 Hull Design designed by Naval Architect C. Raymond Hunt & Associates
  • 100% Hand Laid fiberglass Hull & Deck
  • Composite Stringer System and Transom
  • Nonskid Fiberglass Liner
  • Stainless Steel 316 Grade Through-Hull Fittings
  • Deck Hardware - 316 Grade Stainless Steel Through-Bolted
  • Stern Eyes - 316 Grade Stainless Steel. Rub rail High Density PVC w/ Stainless Steel Insert
BOW AREA:
  • Fish Box/Dry Storage TWO(2), insulated 120 quarts EACH on Port and Starboard Sides that drain overboard by gravity.
  • Seating: Port & Starboard Bow Seating with Removable White Cushions (Never Used) with Forward Facing Foldaway bolstered backrests TWO(2)
  • Molded Forward Console seat with cushion & Backrest (seat cushion never used)
  • Access Forward at One Level - all the Way up to the Anchor Locker
  • Drink Holders - Stainless Steel
  • Storage: Forward Anchor Locker w/ Rode Storage
  • Bow Combing Bolsters
CENTER CONSOLE:
  • Accessory Outlet – USB Port
  • Ritchie Compass
  • Yamaha Helm Master EX Joy Stick
  • Drink Holder - Stainless Steel
  • Large Recessed Area on Top of the Console to Sit Your Sun Glasses/Phone etc.
  • Flush Mount Electronics Area
  • Spacious Compartment in Console – Large Stand-up, Lockable, Portable Head w/ Overboard Discharge or Deck Pump-out (Never Used), Dome Light, Hand Hold, Mirror on the Inside of the Door, and Large Storage Shelves and Locker Hook
  • Easy access to the (2) AGM Batteries and neatly organized wiring in a lockable compartment in the console.
  • Steering Wheel - 316 Grade Stainless Steel w/ Power Knob
  • Windshield – Full Height Wrap Around Windshield Providing Plenty of Protection, Scratch Resistant Acrylic Windshield Integrated into the T-Top structure with an Unobstructed View. Windshield Wiper.
  • Molded footrest for two
CENTER CONSOLE SEATING:
  • Seating w/ backrest , split flip-up Bolsters
  • Large Lockable Dry Storage Compartment under the helm seating
  • Tackle Storage: (4) Plano Boxes
  • Storage Net Compartments on either side
  • Knife, Pliers and Rig Holder
  • (4) Rod Holders behind the seats.
T-TOP:
  • T-Top (Fiberglass) with Painted Aluminum Frame, which is Integrated into the Console Structure
  • GEMLUX Outriggers with 18’ Collapsible Carbon Fiber Poles
  • Overhead Electronics Box with VHF Radio
  • Storage Net Underneath T-Top
  • LED Spreader Lights (2) molded into the T-Top fiberglass
  • THREE(3) LED Recessed Lights, (Toggle switch:Red, White, or Blue)
  • Rocket Launcher with (4) Rod Holders
  • Grab Rails Along the undersides of the T-Top for Safe boarding/de-boarding
COCKPIT:
  • Battery Select Switch Compartment – One Switch for Each Engine
  • 30-AMP On Board Battery Charger with 50’ Cord to dockside power.
  • Cockpit Freshwater Engine Flush for each engine inside boat on Starboard side
  • Cockpit Freshwater Shower (Recessed) with 20 Gallon Water Tank
  • Cutting Board on top of the live well
  • Foldaway Aft Bench Seating for two.
  • Gunnel Rod Holders (4), 316 Stainless Steel
  • Cockpit Lights under gunnels - Blue LED
  • Rod Storage Racks - Horizontal (3) Port and (3) Starboard
  • Cockpit Coaming Bolsters
  • Cockpit Toe Rails for Safety
  • Raw Water Washdown
  • Raised 185 Quart insulated Transom Fish Box with overboard drain.
  • 32 Gallon Transom Live Well with blue gel coat and blue light
  • Transom Access Door /Tuna Door with highly engineered stainless steel latching mechanism
  • Integrated twin engine mounting system with swim platform with telescoping stainless steel ladder.
  • Recessed Bennett Trim Tabs with Indicator and Retractor
Reactions: Pat Hurley
That’s great Brad !! You will certainly enjoy the ride. Nice upgrade.
