- Oct 14, 2018
- Age
- 47
- Voyager
Wondering if anyone has experience in replacing the livewell drain hose? The existing hose is failing and easy enough to remove at the thru hull fitting but seemingly impossible to remove from the fitting at the bottom of the livewell, can’t reach or see, without cutting a hole through the bulkhead in the auxiliary fuel tank area which I’d like to avoid. Any thoughts or suggestions would be appreciated. Thanks!
