- Nov 9, 2022
- Express 265
Does anyone with a 265x use a center rigger? I have bungee clips in two locations on the hardtop for the halyard but that makes it pretty high up to reach. Not impossible, but I’d like something lower. I’m thinking that I wrap around the rocket launcher but that could have the 400lb mono rubbing on the actual hard top. If I pull to one side or the other and tie to the upper rod holder it would impede using that rod holder for trolling which typically has my long rigger bait.
Where do you tie off your long rigger line if using?
