265 transom latches?
jekyl
Townsville Australia
whilst coming home in a following sea at night with Ken Lahr aboard (not his fault)the transom fell down.
Ken believes there is another catch that ought to lock the transom in place.
Have any other 265 owners had this prob. and should there be another latch apart from the two spring ones on either side .
I can see that it would be a good safety idea.
The transom door is closed by those snap latches only!
Don't drive your 265 thinking that transom door will stop a wave breaking over the stern.
There are 2 latches on the size, that is all that holds it, they do become loose over time and should be able to be tightened with a screw driver, if that does not fix them, a marine supply store should be able to get them and they are not that expensive, I plan to replace mine next week even though they are perfectly fine yet.
mronzo, I understand where you are coming from that you should never trust it, but my 265 has taken many big waves from all angles, including the transom well, I've backed down on fish offshore and not once have I had an ounce of water come into my cockpit from the transom well. If all components and hardware of the well door are up kept, it will work as it should and it will not let water pass through. I agree you should always be cautious and assume it will not always work, but this design is very effective, and much better then older notched transom boats and their wells. If your 265 is getting water into the cockpit from the transom well, you have something else wrong and should panic, but the boat has enough flotation to prevent water from entering the cockpit, the transom notch is at the level with the cockpit, so no more water then that can accumulate in the well. If you are getting a good amount of water through that door, chances are you are in real trouble, either your boat is loaded too heavy/ wrong, hardware on the door hasn't been checked and upkept enough, or more then likely, you are out in conditions far worse then you should be for that boat. Don't let an open transom scary you, they are safe, it is typically the conditions boats go out in that causes the problems.
i agree , but other than making it more likely you will mark the engine cowlings when you forget to unlatch the transom and raise the motors . It does seem a good idea to lock the transom a bit more securely.
I have been in many gameboats with water pouring over the transom chasing a billfish in reverse but I am not about to try that with outboards or a fold down transom or 4 small scuppers!
Well, thats interesting to say the least. For the uninformed (me) is where a reason why Grady would not put a safety latch on the fold down transom? The Tuna Door on the Sailfish has a way over sized latch on it. Don't get me wrong, I am a super fan of the 265 (because of the fishability of the transom) and would be in one now if not for the deal I got on my current boat.
I think that the safty consideration is to not lock this fold down transom in place.
If someone lifts the motors to high with the transom up, and they start to hit the transom, it just pops open and folds down via the piston on its own.
If it was locked in place, you would have broken items.
The connection on each side is made using spring loaded ball latches. As the spring wears, you have to turn the adjustment screw, applying more pressure to hold it in place. This is the third season with the boat and I have had to adjust it once.
Tim
i rigged a secure latch on my 265 transom. if i can get pics of what i did i will post them
