4 blade prop's HPDI 200's Grady 265
bac0701
any of you guys with HPDI's try 4 blades on your 265s? been toying with the idea was going to try and find a used set this winter /fall
What are you running now? I just bought this exact setup this Spring.
Going to a four-blade will help hole-shot and top end fuel economy. HOWEVER, it will cause issues if you slow troll live bait as in King Mac fishing. If you make the upgrade, you may need to drop a 5gal bucket over the side and tie it off to slow your boat to the proper bait speed. Live baits need to be able to swim, not be dragged thru the water. Ed Miller, HI-Tec Marine in Essex, Maryland is an expert on 3-blade to 4-blade change overs. WWW.HI-Techmarineservices.com.
If you troll with 2 motors today, you can always drop one and alternate every other trip. I do this a lot to find the right SOG.
