- Jul 19, 2020
- Age
- 60
- Overnighter
I recently purchased a 1988 Overnighter 204 and the alarm isn’t working. As a result of an overheat due to a bent water tube to the power head not seating properly in the water pump and a bad grommet on the upper part of the tube I am in the middle of a rebuild. Before pulling the power head I grounded the wire to the sending unit in the heads and plugged off the oil side of the VRO and never got an alarm. There is no audible alarm when turning on the key. Does anyone know where I can find a wiring diagram or first hand knowledge of how this is wired or a way to wire up a new alarm. I am bypassing the VRO and pre mixing so I can run my kicker off the main tank so I just need it for overheat and fuel restrictions. Thanks in advance for any advise.
