- Apr 23, 2019
- Age
- 71
- Marlin
Recently purchased 92 Marlin, twin Yamaha 2stroke 250's. Hull seems solid, engines run well. Electrical needs work. Currently 4 Optima blue tops wired in pairs parallel. While I would like to do a complete rewire, because we are not full time at the boat location it would take to long to complete. Plan is to clean up as best I can but use parts which can be carried over to rewire should that ever get done. Must change battery charger, looking at pro sport 20 charger. Want to remove or disable factory ac system and run dc wire to cabin and use an inverter (2000w?) for the limited ac we will need. Helm panel really needs work. Will replace all switches and what wire I can easily change. I am thinking I would prefer a remote fuse block instead of the push breakers currently being used so will need to fabricate or have fabricated a new panel. Have not decided if I will change light fixtures or just plug in led bulbs to current ones.
Any comments or suggestion appreciated.
