- Jun 26, 2018
- Age
- 65
- Long Island, NY
- Islander
The transom of my '95 268 has seen better days.
Removed the twin engines, removed the Bang cap and fiberglass cap.
Next I find a piece of aluminum the width of the engine well, ~60 inches in length, mounted on the top surface of the transom (~2") then bends down on the inside of the transom.
Surprisingly the wood isn't in horrible shape, better than I expected. The problem is on the starboard side, the transom "separated" at the end of the plastic cap//bang cap.
I removed the piece of aluminum previously described.
Question: how thick is the transom from the outer skin to the inner side of the transom?
See attached pics, you can see the space between the wood and the engine well, don't think these 2 surfaces are connected as the engine well is part of the top of the boat.
