- Aug 25, 2020
- Age
- 75
- Fisherman 230
I just purchased a 2014 Fisherman 230 with only 167 hours on a 2014 yamaha 300xca,,, it was used near VA beach where the marinas use ethanol fuel,,, I live in Ocean City Md ,, where marinas have non ethanol which I have used in all previous boats. During sea trial in Norfolk VA the engine performed flawless, also when put in water here also run flawless until I filled tank with fuel to mark the water line for bottom paint. Shortly after fueling boat we were headed back across bay at about 3700 rpm when engine shut down abruptly,,, it started right up and got back up to same rpm and did it again . This happened 4 times. Made back to slip ok,, next mourning I went to boat and I felt the primer ball and it was soft,, I tried squeezing ball it did not get hard. Took boat out with my wife for a 1 hour cruise and it ran perfect. Next I marked the water line and had bottom painted and replaced the primer ball ,, when put in water could not get Yamaha ball to prime,, had an old mercury ball and used it and was able to get line primed. Next day I had 6 people and board and had no problem ( however much of the time was idling in no wake zone ).. Next evening went out with my wife and son and started happening again and noticed that when it happened the ball went soft. Replaced line from water seperator to ball ,, still had problem . I am convinced the problem is on the tank side of seperator,, any Ideas,, just spent alot of money on this boat and going CRAZY !!!!
