I see your tank is in the same area as mine. are your outboards mounted directly to a notched transom, or do you have an enclosed transom? Reason I ask is that if you have the notched transom, every now and then a large amount of water can come over it into the cockpit. If you hinge that rear cover area, that could create inlet for water entering bilge in large amounts. I recall one time far offshore when I was in dire straits in a 22' Seafarer with notched transom. Waves were breaking over the bow for considerable time, and cockpit floor was swamped for hours and drains could not keep up with water coming in. At times it was so bad water poured out of boat over the transom notch. If I would have had a hinged floor cover in that boat, I would not be here to tell you this. Just food for thought.
