Adding raw water washdown to a 180....
Greatty
Nantucket, MA
...thinking about it for a winter project. Sick of using buckets and sponges after bleeding out fish. Would like to see some pics of the factory option, if anybody has some, or if anybody has added this option to a 180 would like to see there setup. Any input appreciated! Thanks, Bob.
http://www.shurflo.com/marine-products/ ... fault.html
You're going to need a pump. My Grady uses Shurflo like in the link above. The next bit is access to a thru hull. I would use a "Y" valve in order to divert off an existing one rather than drill a new hole is my bottom. Then you're going to have to find a place to install a hose bib. http://www.gradywhite.com/180/comspecs/ That's a pic of the factory installation on the current Fisherman 180. It is a factory option not standard. If you download the factory manual for the Fisherman it should show both hose routing and a wiring diagram. You'll need to run wiring from the batteries to the pump and a switch on the console.
Not a huge job if you already have the livewell option. You can tap into the thru-hull and use a Y-valve, as the previous poster mentioned.
Get as big a pump as your wallet will allow you...the extra pressure makes a difference.
