- Apr 27, 2005
- Long Island, NY
- Sailfish
Earlier in April about a zillion subjects ago, there was a thread on tht about aligning twins, how to.
They get wild at THT. Guys talking about running one engine free. Woa!
I guess I can drive my FWD car with one tie rod disconnected, probably steer fine but don't think I'll get the same steering performance as with both wheels steering.
I figured out a way to do it two years ago when I rigged my own, didn't see anyone suggest it at THT, close but not the same, so for the DIYers out there ONLY - may save you some time and bucks.
My dealer said: for engines on transom, toe in, for engines on bracket tow out, then he gave me a spec, which I forgot in a second since there was no reference to where to measure it. The dealer must have a marked tool for this task.
I figured if I could get them parrallel, then I'd just add a noticable toe out, and be done.
Nothing down there but curved surfaces, except the prop shafts, not long enough though, so I used the props. The trailing edge of the prop hub is purpendicular to the shaft varying only slightly around the circumference.
I positioned a metal straight edge across the two props half way up, and worked the tie rod adjuster and engines to get them even, spin the prop 1 turn to average out the slight hub tolerance. Disconnected the engine from the steering (I have one cylinder) so I coud jog the engines at the stern, otherwise need a helper at the bridge.
With even contact averaged at 4 points on the straight edge, the engines were parrallel to each other and the ship's centerline. Now I took 1/2 turn of adjuster at a time to just break into a toe out, didn't take much. That's it. There is some play in the tie rod, I averaged that out too by pulling and pushing apart the engines and taking the average.
Can't say if performance matters or doesn't how they are aligned with respect to toe, don't have the time to experiment.
Have fun.
Have fun.
