Due to a series of issues I finally pulled the Mercruiser180 (3.7L) out of my '88 Overnighter and had it rebuilt. I'm now in the process of bolting everything back on before reinsalling it. In several different forums I've read about this motor's infamous stator charging system, it's water-cooled voltage regulator and the costs of repairing them. I haven't had a problem yet but I'm at an ideal place to convert this motor to a modern alternator system. I'd like some feedback on this modification. And if it's highly reccommened by this GW panel I have several questions: 1) should the old stator assembly be removed from behind the harmonic ballancer (is there anything that can come apart in there and be a problem later)? 2) Some conversion ads say they use a common marine alternator found on many newer mercs. Anyone have any part numbers or aftermarket sources? 3) I have experience with metal fabrication (and all the tools) and none of the brackets in photos I've seen look very difficult. Have any of you guys made your own brackets or know of a reasonably priced source? Mine has power steering. 4) Anyone interested in sharing their alt conversion story with tips and lessons learned?
