- Aug 26, 2015
Several Years ago, while I had the engines off my 2005 265 Express for the exhaust kit install, I replaced the aluminum transom cap with one I fabricated out of stainless. During that time I discovered an odd substance growing out from the margin where the hull layup meets the aluminum bar they lay up in the transom. This goopy substance seems to be the result of a chemical reaction where the aluminum and glass resin come into contact. Someone at Grady confirmed this. Now, readying the boat for a repower, I'd like to eliminate this reaction before I glass the transom closed once and for all, hoping that the goopy residue stops pushing its way out of cracks, and hoping to avoid any possible swelling this could cause. Has anyone here dealt with this before, and if so, did you find a solution? I thought I would treat the aluminum with an acid wash and then some sort of coating like zinc chromate, but I am hesitant to risk getting acid into the wood of the transom, particularly immediately prior to sealing this joint once and for all. Thanks for any suggestions.
