- Sep 26, 2009
- Massachusetts
- Express 330
I have a Simrad AP 22 installed on my 2003 330, and assume it is original equipment. The helm is a sea star. What I’ve noticed is that the autopilot will wander a bit, leaving an S shaped wake. It seems to be worse in chop than on flat calm conditions, but it happens then too.
I’ve also noticed that when manually steering, every once in a while there is some “slip” or “jump” where the wheel turns easy. The seastar system has been bled a couple times since I acquired the boat in 2019. I have no reason not to believe this is also original.
Fall is rapidly approaching and I’m starting to think about the winter punch list items. Thinking about having the sea star helm removed and sent out for a rebuild, assuming that the interior seals are likely the culprit of the steering slip and even if not, the system is 20+ years old, and it is a good idea from a preventative maintenance perspective.
On a canyon trip last week, I sort of put these two things together in my head, and wonder how likely is it that the autopilot wandering may be related to the steering slip I experience? I’ll note that I have zero experience on new boats, so I’m not sure if that slip/jump is normal or not. Also don’t have experience with other autopilots, and wonder if my expectations are high, or if a new autopilot would correct that wander, even if the helm was not rebuilt.
