I just changed out my fuel tank sender units with new ones from Royce Industries. (THEY WORK GREAT !!) You can add for a few bill a sensor that will tell you when you are near the top when filling up. It will beep at you. Check out their website. They are the same ones that Grady marks up and you can buy direct. They were about $44 each buying direct. (http://www.royceind.com/)
When I pulled the ORIGINAL sender unit from the main tank, the screws were EXTREMELY tight even after the repeated soaking of liquid wrench. Once I got the unit out , I realized the bottom of the plastic tube on the sender unit was missing . The auxiliary tank bottom was in place so I am a little concerned that it might block the tank pickup. Anyone else have this problem or a fix for this? I am seeing myself draining my tank on a hill and using a flashlight and one of those long tools used to pick up screws. They kind of look like a claw on the end and you use you thumb and forefinger to open and close them. What do you think???
Thanks,
Ray
Thanks,
Ray
