- May 28, 2025
- Age
- 61
- Express 330
its a ShurflowDifferent boat and no problems with air locking the pump.
What kind of pump and do you have a clamshell water pickup?
I'm using the Rule DR47 1100 GPH pump. I have had pumps damaged by the water pressure from the clamshell pickup. Alter a lengthy process and discussions with Rule the engineers told me to drill 3 x 3/8" holes in the back of the clamshell.
Thank you Bill. Mine has the same. I really need to find out what is causing this. Its very frustrating.2007 330 don’t have that problem. Might want to check and see how the scoop looks on the bottom. I seem to remember mine has a slots facing forward and is closed on the aft end.
That's an engineers answer not a practical one. Problem is the high pressure on the clamshell will push water into the pump past the cheap seal. After that the pump is toast. I have also has boat sitting on the bottom at night in the slip sucking sand up damaging the seal and even eroding the shaft (they snap the impeller off). This is specific to the Rule bait well pump which I have.Some boats specify that you should not run the pump when at speed. The water pressure from the scoop is more than enough to fill (and possible overflow) the bait tank
Many boats do that, the to bow open clamshell pushes the water in the system, my BW 23 Outrage did that and my Venture 34 also, but as far i remeber it was not stated in the user manual, but soaked stuff teached me that i rather move the valve to the washdown position.Regardless, my previous Mako stated in the user manual that if you left the livewell fill valve open, under speed the tank can overflow
I'm not convinced that he has a ShurFlo bait well pump. Maybe a ShurFlo wash down. I have never talked to anyone that didn't have a factory Rule centrifugal bait well pump. And I have never heard of a centrifugal pump that airlocked - diaphragm pumps yes but centrifugal no. It's possible GW switched to different pumps in later model years.
The bigger GW's have a centrifugal bait well pump and a diaphragm wash down pump. No y-valve. I think the original post owner needs to take a closer look at his boat. Maybe even at the switch panel.
Please see pic of bait pump. If there is another type out there please let me know. Someone mentioned a Jabsco but said they are noisy and draw more amps.I'm not convinced that he has a ShurFlo bait well pump. Maybe a ShurFlo wash down. I have never talked to anyone that didn't have a factory Rule centrifugal bait well pump. And I have never heard of a centrifugal pump that airlocked - diaphragm pumps yes but centrifugal no. It's possible GW switched to different pumps in later model years.
