Hi all,
I seem to be having trouble with the "1–2-Both-Off" battery switch on my '96 Adventure. Both batteries are in good shape, and no matter which one I hook up to the "Battery 1" cable, the motor will fire up as long as I put the battery switch on "1". But if I put the battery switch on "2", then no matter which battery I hook up to the "Battery 2" cable, the motor will not even respond.
Sometimes, with the battery switch on "2", I do get the boat electronics to turn on, and the check engine lights flash and beep like they always do, and the battery gauge shows a strong reading, as if the boat were ready to go. But once I turn the key further to crank the motor, everything turns off, and then I can't even get the engine lights or battery gauge to respond. (I can't figure out why I sometimes get the lights and beep, and why sometimes I don't.)
So, I got out my multimeter, and followed some suggestions by Seasick in an earlier thread (link below). Here's what I found:
Thanks for any advice!
(Old thread with Seasick's suggestions: http://www.greatgrady.com/forum/viewtopic.php?f=2&t=23430.)
Voltage between positive and negative terminals of battery "2": 13.02V. (Just making sure!)
Voltage between positive terminal of battery "2" and negative terminal of battery "1": 13.02V. (To check the cable that connects negative terminal of battery "2" and negative terminal of battery "1", which has the ground cable attached to it.)
Voltage between end of battery "2" positive cable (where attaches to back of switch) and negative terminal of battery "2": 13V. (To check the positive cable going into the switch.)
Voltage between output cable of switch and negative terminal of battery "2", with battery switch set to "2": 13V. (To check that the switch wasn't broken, preventing current from exiting the switch.)
Voltage between end of switch output cable (where it attaches to the 40A breaker) and negative terminal of battery "2", with battery switch set to "2": 13V. (Just making sure!)
