Bennett tab problem
Shutterbug
Crisfield, Md.
Stb. side tab will extend but won't retract. I haven't yet started checking. The hydraulic pump is activating. Looked at Bennett site and the info for this was, check for low voltage and electrical connections. Thought I'd seek some pointers before starting to dig. Thanks
I had a similar issue with mine a few months ago when I first got the boat, Tom on THT (here also) on the TabMan discussion forum on THT has some great links on how to trouble shoot the switch, its basically a series of making contact with various wires together directly to check if its the selinoid or the switch, once you read over the steps a few time and familuirize with it, its a no brainer.
For me, turned out to be a bad contact in the switch, replaced it for about $79. I think the steps were posted on here a few weeks ago about the same thing?
Shutterbug
I will be delighted to help you get them working. Below you will find the troubleshooting for the system.
How old is the system?
Here is a link to a video that covers the basic system and general troubleshooting http://www.bennetttrimtabs.com/videoplayer.php?vID=10
Here is a link to a video that covers troubleshooting the pump if it runs and a Trim Tab does not move http://www.bennetttrimtabs.com/videoplayer.php?vID=22
Take a look at step 3 below, it will walk you through the test I think will isolate your problem. Make sure that ALL the screws are tight on the back of the switch even if they don't have a wire attached, this could be your problem. Also pay particular attention to the green wire since it opens the valve for the port Trim Tab.
Let me know what you find and I will walk you through fixing it.
Tom McGow
Bennett Marine
Fluid: Automatic Transmission Fluid (ATF) any type. Hydraulic Power Unit is self bleeding, running the Trim Tabs up and down 3-4 times will purge air from the system.
Fuse: 12 volt system use 20 amp in-line fuse on positive. (24v & 32v use proportionately smaller)
Red= Port Valve
Green= Starboard Valve
Blue=Motor Forward (pump pressure)
Yellow= Motor Reverse (pump retract)
Black on HPU=Ground
Orange on Helm=Control Positive
Troubleshooting
1.If one side is not operating reverse hydraulic lines on the front of the Hydraulic Power Unit to determine if the malfunction is in HPU or actuator / hydraulic lines. If after reversing the lines symptom shifts to the other side the malfunction may exist in HPU. If the symptom remains on the same side, malfunction may exist with the actuator / hydraulic lines
2. Is the unit receiving a solid 12 volts? Low voltage will some times cause the solenoids to not open preventing the tabs from moving even though the pump motor is running.
3. Conduct the following test:
Remove the wires from the helm control and touch together as follows:
Operation=Reaction
Orange (+), blue, red= Port trim tab down
Orange (+), blue, green=Starboard trim tab down
Orange (+), blue, red, green= Both trim tabs down
Orange (+), yellow, red= Port trim tab up
Orange (+), yellow, green=Starboard trim tab up
Orange (+), yellow, red, green= Both trim tabs up
If the trim tabs function correctly for each wire grouping then the switch is at fault. Also note that any loose or missing screws on the back of the switch (whether a wire is connected there or not) can cause the pump to malfunction.
This test may also be done right at the pump by substituting a "hot lead" for orange. There is usually a connector to the wire harness within a foot or so of the pump. You want to check this connection for corrosion. You may wish to cut the connector off on the pump side and try the test on bare wires.
4. If you suspect corrosion on the wire connector near the pump, cut it out, test as above and reconnect using butt splices.
5. If you conclude the problem is in the pump, contact me. Bennett Trim Tab Systems carry a five year warranty.
6. Check to see if there is a relay in line on the wiring harness near the hydraulic power unit. If there is it is an Interrupter Relay (IR1000). It prevents the system fuse from blowing if you try to actuate one trim tab up and the other down at the same time. After you test as outlined above, try removing the relay from the wiring harness and retest the unit.(Note: the interrupter relay is no longer used in current Bennett Trim Tab systems and has been replaced with a Switches that "lock out" preventing a blown fuse).
Thanks all. Fortunately my problem was dirty connection at the joystick control. Started with the ground, cleaned it, then to the green stb. wire at the joystick. That's where the problem was, cleaned the rest while at it. I installed these many years ago, maybe 1989, and had forgotten that they were "hardwired" near the pump. There was no plug. I figured an electrical problem would have been there first but got lucky. I see where the joystick is no longer available.
Tabman, appreciate your reply. I had already done a search and printed your directions down as well as viewing youtube. Extremely helpful and they've a permanent place in the boat cabin with the other paperwork.
They're a great product. The 1 and only problem I've had was a broken joystick since the installation.
Tim
