Hi and thanks for reading.
The ram that lifts the electronics console stopped working when it was in the up position.
If I unplug the connectors for the two wires )black/white) that come from the rocker switch and then supply 12 volts directly to the ram it will operate. So it seems the ram is functioning properly.
The wires (black and white) that come from the rocker switch also has correct voltage when tested in all three positions.
So the ram is functional, correct power is coming from rocker switch but the ram doesn't seem to be getting power when the wires are reconnected. The wire connections are clean so that isn't the issue either.
Thsi should be simple but I don't get it???? What am I missing? Thanks!
