I have a 1993 225hp Yamaha on my Seafarer22, Any tips on bleeding air from hydraulic steering lines?
CJBROWN said:I use the funnel method on the helm too. Plus a length of bleed hose long enough to reach back up to that funnel. As long as your fluid isn't contaminated, you can swivel back and forth on each bleeder 'till all the air is out, simply pumping the fluid back through the system. With a short bleed line it's hard to determine when you've got all the air out.
Makes a funky job super easy.
JUST-IN-TIME said:Best way is 3 containers
2 for both the lines and 1 for the helm
i crack both bleed lines on cylinder and stick them in the containers with half oil
use the 3rd container for helm, when she gets 3/4 empty i fill her up
i can do this in about 5 mins and by myself
it is the best way i found out how do do it
also you only turn the wheel one way and not both, or you will suck air!!
JUST-IN-TIME said:yes, but the auto pilot must be bleed first
catch22 said:Assuming you have Seastar, (Teleflex) steering.
"FILLING & PURGING THE SYSTEM" -
http://ww2.seastarsteering.com/OUTBOARD ... urge.htm&1
I've done it a few times and I don't like their method of attaching the bottle to helm. Imo, it's too messy. I found a small, plastic funnel that fits the threaded "fill" opening in the helm perfectly. Just have to maintain a small amount in the funnel, to ensure the helm is full. You don't want the fluid level to run low, or you risk introducing air into the sytem. When I was done, I would use clean paper towels to carefully absorb what was left in the funnel. You really should have a second person helping you. One person steers and keeps the oil level up, the other does the bleeding on the cylinder.
Also.... the question is, why does it have air in the first place?
You might, (probably) have a leak. Typically, the end seals, (glands) on the steering cylinder develop leaks. When these seals leak, they not only lose fluid, (under pressure) air can be sucked in as well. Look for any signs of leaking, where the shaft enters the cylinder, (both sides). Have someone slowly turn the steering one way, then the other. Look for a build up, (film) of fluid on the shaft. You might even see a drop or two squeeze out. If there is a leak, you'll want to replace those end seals before bleeding.
Replacing the seals is usually not a big deal, provided you can remove one of the black aluminum end brackets, on either side. You actually only need to remove one end bracket, to remove the steering cylinder, but you should remove and grease both. Sometimes those aluminum end brackets can be frozen in place... and that can be a b!cth.
Seal kits are available at many boating stores, (especially on-line). They can usually be ordered with, or without a spanner wrench to remove the threaded end rings. You need to know what model cylinder you have. There should be an ID tag on the cylinder. Example - "HC-5345".
Here's a link for a seal kit, (you might find it cheaper somewhere else) - https://www.surplusunlimited.com/Mercha ... _Code=70-1
And fluid - https://www.surplusunlimited.com/Mercha ... e=2300-130
