Boat lift bunker settings for Freedom 235
Bobfallon11
Freedom 255
Does anyone know the positioning dimensions (width) for the boat lift bunkers for a new Freedom 235.
Grady White will send you a chart with the proper bunk spacing. I have an older version, but you need a new one.
Thanks. I found the published data to be lacking. I worked with the dealer mechanics as well as a boat lift mechanic and we determined that 40” (out to out) at the stern and 32” at the bow with 8” deep bunks was the best setting. Keel sets about 2” above structural cross bars and is very stable. If you don’t pinch in at the bow, you risk hitting the keel at the bow or bearing on the hull chines when you raise the lift.
