Boat Seat Tension Parts
Greyduk
Alabama
Has anyone searched for and found the U-shaped tension bolt for the Pompanette seats? The one I have is frozen on and will not turn. I expect it to break when i force it. Thanks.Seat Spider.jpg
Spray with PB blaster, let sit , spray a few more times. Let sit overnight.DGive it a shot but don't go nuts, it will break. If it doesn't loosen, heat the nut with a propane torch or MAP torch, till it smokes and starts to turn color. It will probably loosen up at that point. I have never had the PB blaster and heat method fail but it may take a few applications and reheating. One possible snag if if the handle on the shaft is plastic. It may melt from the heating
