Bomar Hatch on 265 Express...
bartoma
Seeing a little moisture on the bunk under the hatch... Before I think about anything dramatic, I thought I would replace the hatch seal...
Does anyone know the correct gasket material for the Bomar hatch for a 2001 265 Express?
Very common - easy to source locally.
But forget about the foam seal - either bed it with something like LifeSeal or, even better, butyl rubber tape.
Did you check the screws inside the handles? I just tightened mine and problem solved
