Bow Thruster Battery Location 360 express
Pensacola, FL
I have looked all over and cant seem to find the battery for the bow thruster on my 2005 360 express, I am pretty sure the thruster is not hooked to the main batteries since I have a separate bow thruster charger.
Thanks,
It is located at the helm. You have to unscrew the flip up table and it's housing from the starboard side bulkhead. There are two large thumbscrews on either side at the top of the table going into the starboard bulkhead. Remove those and lift the entire unit out. The battery is located right there.
You have to take the entire unit out - including the enclosure that the table mounts to. the two thumbscrews hold it in. Remove them, lift the entire fiberglass unit up and out. The battery will be on the floor of the bulkhead slightly to the right side. You cannot miss it.
