I recently purchased a 2004 Chevy PU to haul the boat as the Admiral was not pleased with the Yukon Denali. :cry: Hooked up the trailer electrical connector to the chevy to find that there was no right turn lamp operating on the trailer. First I took apart the trailer tail light assembly and found a wire just barely hanging on to the bulb socket. I attempted to solder it on but still had no power. Well off to the boat shop to purchase some LED tail lights. Left side worked like a charm, right side nada. Continuity from the lamp to the trailer connector was good. Ok, up to the connector on the truck. No power to the connector. OK, so there is a problem with the wiring harness to the connector. The truck lamps worked fine so I discounted any fuse problems. Fussed with the wiring harness cleaning the connectors without success. So far, $100 spent and about 1 1/2 hours Friday night before hauling to the marina the next morning at 4 AM. At least I had running lights and a left side brake lamp. (not keeping me at peace when things are not perfect) Well, we got to the marina 90 miles away without a problem and fished the day away. Well, if anybody else is like me, I dwell on things like this light problem until they are fixed.
I decide to do some internet research and find out that there is a dedicated fuse for the right turn trailer lamp connector, low and behold, the fuse is dead, DUH
Now the boat and new LED trailer lights are at the marina and I have the truck at home. I had no idea they had a dedicated fuse for each trailer circuit, Right turn trailer, left turn trailer etc. That is some smart GM engineering though. I wish I would have known this before. The LD's do look nice.
