Broken Sink Bait Station
JRuss282
Good day, I have a 2002 282 Sailfish with dual sink on port side at stern. I was having some oil tank troubles and to clearly see everything I needed to remove the battery switch box and also cut caulk and pull the sinks. Anyhow I inadvertently damaged one of the sinks. There are two drain hoses one of them broke at the connection at the bottom. I think just age and was brittle.
The Question because now I am home and forgot to check. Is that one piece? or can that drain piece be replaced or modified because I sure don't want to buy a new sink?
Regards
