- Sep 14, 2016
- Age
- 62
- Sitka Alaska
- Website
- www.prattcustoms.com
Hi guys. New to the forums.
Last Fall I acquired a 26' islander that was severely neglected. The price was right ($5000.00) so I bit!! This was a "as is where is" deal. Both motors needed midsections and lower unit cases due to electrolysis but only had 500 hrs. on them so that was a plus. I found a couple blown motors cheap so I swapped out the power heads and was good to go.
I do quite a bit of fiberglass work on the side mainly for myself and enjoy making "one off" parts for our cars and boats. I thought, since I haven't seen any threads on making parts, I would show how I am going to do mine.
The Grady had several blemishes in the hull so I repaired them and re gel coated from the rubrail down and added a dark blue stripe. I had some silver decals made to replace the old ones.
Unfortunately Grady did a poor job building the hatches for these boats. After the gel coat was sprayed in the molds, a colored putty was put around the edges to soften the radius so the fiberglass would lay in easier. This process saves time in production but the end user gets hosed if they get banged. This boat was used by a carpenter in S.E. Alaska building on private islands hauling materials in the boat. Needless to say, ALL the hatches were toast. The anchor rope bow hatch was missing so I am making a replacement from a template.
This is what I started with:
The transom door was filled with scraps of 2x6's as a core. You can see the whole bottom blew out when the wood swelled.
For the missing anchor hatch, the template was made initially from a piece of paper held over the opening and creased while rubbing my finger around the opening. This was transferred to cardboard and final trimming was done to get the proper clearance.
I have several sheets of fiberglass covered urethane foam used on commercial roofs for hail damage resistance. The foam is very dense and is great for making panels and molds. A putty knife peels the fiberglass skin off one side of the foam making it flexible in one direction. Cutting several slits in the foam allows it to bend easily around the radius. A hot glue gun holds it on the form board and silicone makes the radius between the top and sides. Several layers of silicone builds up the radius to what Grady used.
I'll post more as I get going.
