Can’t reach lower transom mounting bolt!!
mleads310
Brooklyn NY
I have a 2001 282 sailfish. I’m here in the middle of a re power and can’t seem to reach the lower inner outboard mounting bolt. I opened the deck plate and can barely get my fingers on it because the stringer is in the way. My fear is if I remove it, which I have to because it’s stripped, that I won’t be able to slide a new one back in. Any tricks other than cutting out a larger deck plate?
Side note I will be doing some fiberglass over the seem at the band cap which will be easy in comparison to reaching this bolt.
So tap that one out with the hammer, then there is a tool, I hope someone here can give the name, it's a wire, on one end it is curled. you put the curled in through the hole from the outside, then on the inside thread the new bolt in the curled end, and then pull it from the outside, pulling the new bolt through the hole. I've seen this used in automobile applications to get bolts in to frames. EDIT: This link is what I'm talking about, you'd need to find one that fits your bolt.
Wire bolt leader
Bingo - the exact thing I was going to mention... thanks for doing the brunt of the typing, John! It's funny you linked to Curt - 30 years ago, I bought my first Curt trailer hitch and it came with that "tool". I had never seen that before - what a GREAT idea to get bolts into blind holes through a frame!
A skinny, flexible friend with long arms is another option.
You "might" be able to at get the bolt started into the hold - even if it's at a bit of angle from where you are holding it - and then tap it into the hole.
This is a good opportunity to drill the holes out a bit bigger, then fill with epoxy to soak into and totally encapsulate the wooden core, then re-drill your proper size hole.
Are you saying you are reaching thru a 6" piehole?
Not familiar with the 282 layout but if possible, unscrew and remove a deck panel. That will let you in there with a shoulder or two.
Later, put in a larger deck hatch so you can get a shoulder or two elbows in there.
Those pie holes are stupid.
something like this. I'm talking in the deck not the motorwell. Don't put a big hatch there
Also, consider installing the lower bolts from the outside -in. Put the nut & washer on the inside.
The lower bolts are below waterline. Doing it that way allows you to start the bolt in with clean thread, then cover the remaining bolt with sealant and push it in.
This seals hole from the outside...where the water is....
Also a good time to get in there and clean up & reinforce the glass inside.. Very likely a "ring" in the glass from the washer.
I installed some backing plates
Thank you fellas for the tips, I ended up getting the skinniest kid in the yard and said $30 if you don’t drop it and if you do drop it then run. Got them both lol. I can’t believe Grady didn’t move the pie plates over just 2 more inches over to clear the stringers. Insane. I appreciate everyone’s help!
Reactions: A&J Outdoors
We call them "Bilge Monkeys" :)
  • Haha
Reactions: mleads310
