Center Rigger Rigging on 330/360
pablor
Hi,
I have mounted my 45 degree center rigger and I am not sure where to mount the eye hook and the halyard so that it can easily be reached bo shorter people. Any ideas?
I think the easiest is to run the halyards to the hardtop vertical rod holders (I run mine to the second from the top)-- If you look at the rod holder, there should be a very small hole in the base-- I rigged a very stainless carabiner/ shackle through the hole and rigged all of my cords to this clip--
Works great--
Great idea! Does it matter that the line is running almost sideways from the last eye of the rigger to the side of the boat? What kind of rigging did you do, do you have a pic?
Pablor-- I will post a picture of my rigger set up but no problem running the line to the side of the boat-- I use roller troller clips and double rig (one to each side) my center rigger--
Great!!!I would love to see some pics...
