CFMoto accessories
Redehin
Wahoo
I just picked up a ZForce 800 Trail and I’m trying to avoid hardwiring anything if possible. I was thinking about plugging a 3-way cigarette lighter splitter into the factory 12V outlet and using that as a power source for a LED light bar, a small Midland 2-way radio, and maybe a Bluetooth sound bar.
The splitter has individual on/off switches, and I wouldn’t be running everything at the same time. Has anyone done something similar with CFMOTO accessories, and did the 12V outlet handle it without issues? Just looking for real-world experience before I go this route.
Compare the rated amp draw of your accessories to the rated ouput power of the socket. I'd also double check with the wiring size and fuse. Do NOT increase the fuse.
Once you investigate that info, you'll have your answer.
Will the 3-way bounce around in the socket and possibly cause arcing... which could cause fuse popping and/or damage to the accessories.
