- Jan 23, 2018
I have a 2006 Grady White Chase 273. I noticed a leak on the hydraulic hose fitting on one of the motors. My plan is to replace both hoses because as I researched, you can’t fix a bad fitting. It’s better just to replace the whole hose. My challenge is knowing the length of the hoses without pulling one out. Because I’m going to replace both, I’d rather attach the new hoses and pull them out at the same time l…  So how do you know how long the hose is without pulling one out?
I guess I could pull one hose out and then put two new hoses in while pulling the only one left, but I’d rather pull both out at the same time while pulling new ones in if that makes sense.
Anybody have any idea of hose length from the outboard motors to the helm?
Thank you.
Thank you.
