Circuit Breaker - 2003 330 Express
loubeer
Newport Beach, CA
I need to replace a circuit breaker on the main panel of my 2003 330. It has a red light that signifies that the breaker is "on" - the breaker works, but the light is out. Does anyone know the manufacturer? It seems that Blue Seas is the predominant breaker out there, but that's not what I have.
Thanks in advance!!
This is the breaker - sump pump - light burned out.
So the pump works right.
What makes you certain that the light is part of the breaker? I would be very surprised if it were...
Have you looked at the back of the panel? Removed the breaker and get amp value, part#/Mfg name?
Yes - the circuit breaker is working - only a light issue. I was hoping that a member has dealt with this issue, gives me the info and I could have a replacement breaker in hand before removing panel and taking out faulty breaker.............. You'd think that Grady used a readily available breaker from a well-known supplier?!?!? I am assuming that on/off light part of breaker assembly, but not sure.
No matter the problem, to fix it you are going to have to remove the panel. So, remove the panel now and look at it.
I am 99.9% sure that its a typical breaker and the separate light is mounted on the panel.
Issue resolved. SkunkBoat was correct - the light is not on the breaker. The light is on the circuit board very near the breaker. I followed the wire from the light and it had worked loose from a crimp connection on a spade terminal a few inches away. Re-crimped connection and light is now working.
