I have a 1999 Bimini 306. When ever I pop off the cover of the access holes above the fuel tanks I find they are wet on the inside cover with condensation build up - all summer & fall.. Also it drips top of the tank. There is always a puddle on top of the tank around the fittings both front and rear tanks. I resealed the fittings last year so its not leaking around the mounting area. Also fresh o-rings. These are pop-top fixtures.
Looking for other people's experience on this. Is that just the nature of the pop-top port hole fixtures. It's made me wonder if I have excessive moisture where the fuel tanks are.
So I bought an endoscope on amazon for $30 and ran it down the rear of the rear tank to the lower deck that the tanks sit on. I did not see any puddles. BTW the endoscope works awesome for $30 (records and takes photos and has a light). Did same on the front side on the front tank. No puddles down below. Wondering if there is just enough condensation build up from the aluminum tanks to draw moisture from the bilge area.
I also reached inside the access hole and felt around on the underside of the deck and did feel some moisture in a few areas. The water on top of the tank is localize to the port hole areas despite some areas being moist on the underside of the deck. Also not sure if that's condensation or if the the center floor panel may need to be pulled up and rebuilt.
Anyway I really am trying to avoid standing water on top of the fuel tank fittings. Any advice welcome on experiences w/ this.
