First thought is impact damage but it would take a lot of force to crack that housing? Was the prop shaft bent?
Second thought is water freezing and cracking the housing.
Third thought is that something got jammed in the bearing carrier and pushed out the sides of the casting.
If you turn the shaft, does it do so easily without grinding?
